Atmel bascom avr 8051 proje devre arşivi
Atmel serisi ile (AT89C2052, AT90S2313, AT89S8252 vb.) çok geniş kaliteli bir arşiv PIC serisi mikro denetleyiciler ile yapılan bir çok devrenin atmel versiyonunu bulabilirsiniz.
Usb, alarm, lcd, nokia 3310, nokia 6100, display, led, sms, telefon vb. bir çok devre bulunuyor bazı projelerde protel pcb şema dosyaları visual Basic programları var atmel ile ilgilenen kişilerin ziyaret etmesi gereken bir site gerçi PIC kullananlarda bakmalı çok ilginç projeler var örneğin “Excel üzerine veri transferi”
Kaynak: Application notes mcselec.com
| Bascom AVR Proje, devre listesi | Bascom 8051 Proje, devre listesi |
Dimmer
EEprom programmer (Part 2) RC2 sound / Voice playback (Part 1) Radio Range Detector The Graphic logotype on text LCD Snowflake Camera project with M162 Rheobas four-channel LED Runstring Implementation of IR NEC protocol VGA AVR – BASCOM Video controller Digital Melody Player Useful modding – spectrum’s analyzer + watch MP3 Player Led 3D-ball matrix Nordic nRF24L01 with BASCOM-AVR PID motor controller Sony Remote Control Decoding LCD display with touchscreen Car Windscreen Wiper Control with ATtiny13 Loopback test Transfer data between MS Excel & MCU CodeLock AVR MCS Bootloader Using MAX1668 with BASCOM-AVR M8 Bootloader IR touch panel Using MCP23016 RPM meter and rotational speed sensor KMI15/1 with AT90S2313 Valentine Heart SmartCard4 Electronic Lock FlowMeter for ULM FAT32 WAVE Player 90S2313 Alarm Clock Interfacing external I2C EEPROM T6963C Graphical Display Pseudo Multitasking Real Time Using the AD7895-10 Bipolar AD converter Graphical Clock Moving LED messaging Waver with BI-colour LEDS FAT16 File System Driver for CompactFlash Network programming with the NE2000 How to set up zero crossing software trigger Triac SMS on Nokia 5110/6110 via microcontroller Accessing a Compact Flash Card from BASCOM Showing custom fonts on the T6963C Sony IR receiver using the SIRCS protocol RC LapTimer I2C LCD and Keboard library Sending an SMS with the Siemens GSM M1 module Reading the SHT11 Humidity sensor Quadrature Decoder/Counter and Display Getting started Data Transmission and Error detection with Correction Green House controller Speed controller for model boats Dual Thermometer with the DS18b20 Dutch BASCOM-AVR course, AT90S2313 PDF in Dutch PID Controller BASCOM-AVR Hotchip cable Logarithmic bar graph (LED and LCD) A RealTime RTOS Sending RC5 and SONY IR codes Measuring temperature with 90S2313 and BASCOM-AVR Serial to GPIB converter 1 Bit twiddle outputs 74HC595 daisy chained shift registers to control relays BASCOM-AVR example that demonstrates SNAP protocol |
555 calculator using 89S8252
Microcontroller-Based automatic flush system Micro Controller based Code Lock Low cost LCD frequency meter Digital Thermometer-Cum controller with DS1821 ADC using TLC549 serial 8bit IC Micro Controller based alarm clock with DS1307 & MAX7219 Infrared Proximity Distance Measurement Micro Controller based Countdown Timer SMS driven automat Realtime clock with LED display DCF 77 clock 15519 Sending SMS using Siemens GSM C35i RS-485 Master Slave Communication Remote Control car by phone DCF 77 clock Count up/down timer LAB PLC Using the T6963 based GRAPHIC DISPLAY How to increase resolution of DS1821 temperature sensor Reading and writing the Dallas DS1991 secure I-button Two examples about Multi Tasking ASCII input with 3×4 keyboard matrix How to decode SONY IR remote control signals Using the LM75 temperature sensor Page scanner Telephone card reader Using the Sharp GP2D02 distance sensor LCD VU meter How to implement flow meter using the 80552 Keyboard decoder Using the TIMER interrupt to make a clock with LED-display Using an I2C clock device with the PCF8583 BASCOM-LT and BASCOM-8051 Hardware simulation Controlling the X9CMME Flash Programmer Big Digit ThermoMeter Reading the DS1820 Temperature Sensor Reading an AT-PC Keyboard Reading the Dallas temperature sensor DS1821 A Garden Watering Program Reading the TLC2543 A/D converter Evaluation board for the AT89C2051 and AT89C4051 |
Yazarımızın 320volt.com Blog üzerinde şu an okuduğunuz yazı dahil 1893 yazısı bulunmaktadır. Yazarımız hakkında bilgileri ve diğer yazılarını görmek için bakınız; gevv
Yazılar e-postanıza gönderilsin
