ATmega168 NIMH Şarj Devresi Java GUI Arayüz
Kaynak Java ve Avr C dosyaları var bilgisayar ile RS232 port üzerinden haberleÅŸme yapılıyor Java GUI Arayüzü bulunmakta Ayrıca devre üzerinde 2×16 lcd gösterge var java ile elektronik devreler tasarlayan kiÅŸilerin iÅŸine yarayabilir alternatif link
Since I purchasable devices were either dissatisfied or me but this simply too expensive appeared, I had a long time before my own battery charger for NIMH to build.The device should be both very small batteries as well as greater load and also with the battery packs from multiple cells can circumvent
Java GUI
In order to capture the readings was a GUI written in Java. For the Serial Communications, the Lib RXTX used.This provides support for various platforms and processors. The program has been tested only under Linux.
# Controller: ATmega168 with 8MHz
# Input voltage: 7V to 20V
# Charging: 5mA up to 2.4 A
# Discharge: 2.4 A max
# Charging: Konststantstrom
# Number of cells: 1-8 (the maximum number depends on the input voltage)
# Serial interface to the data to a PC to transfer
# 2×16 LCD modes for selecting and displaying the battery values
#Four key operation
Ayrıca Kaynak Sitede Atmel AT,ATMEGA Serisi ile yapılmış ilginç projeler bulunmakta
Signalplotter : Very simple four-channel 190kHz Signalplotter and function generator
Wireless connection : Wireless connection as replacement for an RS232 line.
LED matrix : The first was written selbstlaufene demo,then some interactive games such as Tetris or Snake
3D Scanners : A distance sensor, with two servos can be moved.
DCF77 clock : An LED clock radio with some extra features.
IR LCD : A 16×2 character LCD copywriter can be sent via infrared.
Electronic Compass : The attempt an electronic compass to build.
Robo 3 : Testern und Mikrocontroller. A simple robot with stepper motors, sensors and microcontrollers.
Universalbox 1 : AT90S4433/ATMEGA8 with RS232 interface for testing new ideas.
Electronic dice : LEDs indicate keystroke on a random number of dice.
LCD 2 cable : circuit, a 16×2 character LCD with only two cables to your computer.
Robo 1 : robot that moves around a glass to find.
