AT89C2051P ile 301 Ledli Analog Saat
Kategori: Pic Atmel Projeleri Assembly Ccsc Picbasic vb 8/11/2008 Tarihinde yazılmış
PCB Şema Dosyaları ve C51 Derleyici ile hazırlanmış C-hex Kaynak kodları bulunmakta alternatif link at89c2051-analog-led-clock.rar
The clock is built from 301 LEDs with a diameter of 3 mm fi = forming face (this Jend diode is in the middle) and 12 diodes contour hours. LEDs are arranged in seven districts. microprocessor AT89C2051 from Atmel. AT89C1051 with 1kB source code because the clock takes up less than 500 bytes. Chart clock Port P1 chip serves as a data bus through which data are sent to memory in 74573
