2 Uygulama var pic16f626 ile yapılan uygulama pwm ile ledleri sürüyor büyük ihtimal çeşitli efektleride var proteusda denemek gerek diğeri ise basit seri bağlı ledler ve sınırlama için dirençlerden oluşuyor çeşitli renklerde ledler kullanılmış yeşil mavi tüm uygulamalr için Alternatif link
LED neon Control unit
This option LED neon electric site is completely the same as for construction of LED neon, but what is covered is light emitting diode lenses Ice but only so that they are opaque and do not create circles This is carried out zbrouÅ¡ení finest abrasive paper (280 or 1000) under ground water (ustridnete a little square abrasive paper, dip it in water and gently grindstone led diodes - just as 5x probrousit around the lens so that the lens LEDs is not clear but watt = variance light It is very simple. Srdcem je mikrokontroler PIC12F629 (IC2). The heart is a PIC12F629 microcontroller On its inputs GP1-5 are connected to the land of individual buttons (TL1A + TL1B … TL5A + TL5B)
LED backlight car using neon
I got the idea to try to replace expensive neon (in the order of 4000) LED neon (material to illuminate the whole car will be released under 1000Kc). This variant of neon from the LEDs I’ve ever seen sold in a number of shops, but as far higher price than if you made yourself
