Power Supply
The circuit board the power supply (Figure1) consists of a Bridge Rectifiers with downstream E Capacitors. The input AC voltage is 1 and KL on the 6.3-mm plug ST 1 and ST 2. The diode D 1 D 4 to form the bridge rectifier. The low voltage of the river This money Schottky diodes reduced the power loss compared to a silicon diode around half creating a continuous current of up to 7 A is possible. Of course, the diodes in this current chilled, but enough already a small aluminum angle out. The parallel to the diode-connected Capacitors C 1 to C 4 is intended to Interference suppression. With the two E Capacitors C 5 and C 6, the parallel Smoothed voltage (buffered).
C5,C6 Kondansatörleri 4700uf
Datasheet Dosyaları
STPS10L60D
