0-40 Volt Switching power supply
Devre yüksek akımlı regülatör L296 entegresi üzerine kurulu 0.40 volt 4 amper akım ve voltaj ayarlı Switching güç kaynağı
Efficency of this switcher is around 85% - and it depends on the load
For the same power output its size is up to 5 times smaller
Element count is small, becouse the regulator chip has everything integrated
Current limit
Adjustable output voltage
Shutdown when overheated (build temperature sensor)
Measure and regulate output voltage
High frequency switching (200kHz)
No 50Hz hum
Becouse of high efficiency, small or none cooling system is needed
Specificaly for the chip that is used in this circuit data are like this: Oscilator runs at freq 200kHz, output noise is below 1% (worst case), max current is 4A at 20V. Voltage can be regulated from 0,0 V (true zero), to 40 V. Voltage and current limit, can be adjusted. You should take special care when purchasing choke. Its ferrite material should be build for frequencies up to 300kHz. Input to the regulator can be DC or AC voltage - becouse the input is rectifier bridge.
Dosyaları Buradan indirebilirsiniz Alternatif
23/02/2008 9:06 pm
[...] Read the rest of this great post here [...]
27/02/2008 12:49 pm
çok ii hatta mükemmel ama ufak bi sorun var entegreyi bulmak biraz zor hele hele benim gibi ufak bi ilçede oturalnara
